How to build a track
Posted by: yz450xtreme---------------------
Hi,
I am in the beginning process of building a large practice track. I have all the equipment I need. The only thing I need a bit more info on are the measurements, angles, and spacing of the jumps.
This is not a supercross track and will mostly be used by intermediate riders to novices.
Does anyone know of a place on the internet where I can get information on building safe jumps that are still fun and challenging.
Thanks in advance,
Mike
Posted by: jboomer---------------------
First and foremost, run a search on the topic and you'll get LOTS of info! I ran a search and this is one of the many links (not to mention straight up advice posted by other DRNers) I found:
http://dirtwurx.com/main.cfm?mc=tra...building_4.html
Posted by: Reddog---------------------
Dirtwurx is a very good site. If you have any hills in your layout you can use those to build tabletops. any jumps that have any distance the face should at least be the length of a bike with a lower angle for distance instead of height. I have built many tracks from SX to MX so if anymore questions just ask.
Posted by: Nevada Sixx---------------------
i did alot of meauring at our local track, most of the jumps allowed in the beginner class are 25-30 feet, and whoops were 15-17 feet apart. mark your track so new people wont end up trying to ride it backwards by mistake. what is really cool is if you have a shade tree nearby to sit under when its 100 degrees outside and have a water hose somewhere.
Posted by: rocky01---------------------
Check out ATVA's website. They have a PDF you can download on track construction!
