Originally posted by marcusgunby pyro could you list the stacks as i dont use the charts myself. |
Originally posted by pyromaniac Sure, i just didnt have them in my head at the time. All are 0.10mm thick from the vavle and out: 21 12 21 17 14 13 12 11 9 |
:scream:
:thumb:
Originally posted by KTM-Lew I agree with Russ that with no mid-valve and the very light stack you are probably riding too low in the stroke......that's what i was trying to say in my last post. :silly: They probably ARE refering to changing the bottoming cone. :thumb: |
Originally posted by marcusgunby Does yours have that shim stack below the main shim stack?? its called a bleed shim stack? |
On bigger bumps at slower speed it works better but i also think my shock is too hard cause it wants to throw me off if i attack too hard. I simply cant ride as fast as i want or the bike will throw me off or make me lose controll, i know i should be able to ride faster if the suspension is right.
