Thumper owners please assist me
Posted by: Thump---------------------
Doing a little research and could use your help.
I need to know the oil capacity for the following bikes with and w/out oil filter change. Motor and Tranny if applicable. Please list your year, model/make and capacity. Thanks guys!
Honda
XR 250, 400, 600, 650L and 650R
CRF 250 and 450
Yamaha
YZ 400F, 426F, 450F, 250F
TTR 125, 225, 250
Suzuki
RMZ 250, 450
DRZ 400
Kawisaki
KLX 300, 650
KXF 250, 450
KTM
All of the KTM thumper models.
Again, thanks for your help on this.
Posted by: biglou---------------------
YZ426F=1500ml, 1600ml with filter change. Not sure if the 400F is the same.
Posted by: evenslower---------------------
My Clymer's for the YZ250F gives the same as Lou's for the 426.
Posted by: Flying Scot---------------------
Thump, for my 2002 KTM 250 EXC RFS it says 1250ml for engine oil quantity.
After checking the manual for specs for the 2002 KTM 400SX, 400MXC, 400EXC, 520SX, 520MXC and 520EXC it is also 1250ml for Engine Oil Capacity :thumb:
Posted by: OnAnySunday---------------------
Xr650R. = 1.65 qt without filter , 1.75 qt -w- filter change.
Says the book that is.
More like 1.75 & 1.85 qts though in real life.
Posted by: Knobbyjake---------------------
XR 600>>2.3 litres (2.4 qts.) after disassembly, 1.9 litres(2 qts.) at oil change, 1.95 litres(2.06 qts.) at oil and filter change XR 200>>1.1 litre after disassembly (1.2 qts.), 0.9 (1 qt.) after draining
XR 100>>1 litre after disassembly (1.1 qts.), 0.9 litre (1 qt.) after draining
TTR 125>>1.2 litres after disassembly (1.27 qts.), 1.0 litre (1 qt.) after draining I know you didn't ask for a couple of these, but they're 4 strokes so what the heck.
Posted by: XRpredator---------------------
XR400, 1.9 quarts/1.8 liter (with filter change) Can't get it all in at once. put in as much as possible, kick it over, run it down the driveway and back, then put in the rest.
Posted by: Treejumper---------------------
2003 YZF450
Total oil- 1.27qts
Periodic oil change- 1.16qts
With oil filter- 1.06qts
Posted by: tnrider---------------------
looking at the shop manuals now for 2003 models
ttr125(all variations) 2003
engine oil - periodic oil change: 1.0L
- total amount: 1.2L
crf450r 2003
engine oil - at draining: 0.66L
- at filter change: 0.69L
- at dissassembly: 0.85L
transmission oil - at draining: 0.59L
- at disassembly: 0.67L
coolant capacity - at change: 1.03L
- at disassembly: 1.12L
Posted by: Patman---------------------
XR250
The book says something like 1.8 quarts but 2 quarts is typically what I use because of the extra capacity of the oil cooler. I change the filter at every change so with/without doesn't apply to me.
Posted by: mag---------------------
CRF450 19.84oz in tranny
23oz in crank
Posted by: Curlyjoe---------------------
Oil change only...
XR250L XR250R................................. 1.3 liters (1.37 US qt)
XR400R.............................................. 1.7 liters (1.8 US qt)
Oil & filter change...
XR250L XR250R................................. 1.4 liters (1.5 US qt)
XR400R.............................................. 1.8 liters (1.9 US qt)
After engine rebuild...
XR250R, 1986 through 1995 XR250L..... 1.6 liters (1.7 US qt)
1996 and later XR250R........................ 1.7 liters (1.8 US qt)
XR400R.............................................. 2.2 liters (2.3 US qt)
These are the recommendations taken from the Haynes XR250R, XR400R 86-97 Workshop Manual.
Posted by: dan1608---------------------
2002 DRZ 400
Oil change.......................1.7 liters
Oil & filter change.............1.8 liters
Engine overhaul................1.9 liters
Taken from the Susuki DRZ 400/E service manual.
Posted by: correcaminos---------------------
All Husabergs: 1 litre
Posted by: Imho---------------------
YZ400F:
Periodic Oil Change: 1.5L (1.32 Imp qt, 1.59 US qt)
With Oil Filter Replacement: 1.6L (1.41 Imp qt, 1.69 US qt)
Total Amount: 1.7L (1.50 Imp qt, 1.80 US qt)
Posted by: plykins---------------------
2002 KLX 300
Oil change-------------1.3L 1.4QT
Oil & filter change---1.4L 1.5QT
Dry engine--------------1.5L 1.6QT
1996 KLX 250-- same as above
Taken from owners manuals.
