Originally posted by weatie181 I have the stock 0.44 springs in it. And I'm with you on the stiffer spring results, but would ya know that 2 seperate suspension website spring rate calculators show I should run 0.41 - 0.42 for my weight being 170lbs without gear. I think one of the biggest problems is that it has been revalved 3 times by a big name suspension shop, but each time I bring it there, a different tech has worked on them. Also I have added oil and it helped a smidge..... |
