Sukuki shock bleed method
Read through the RM manual today(its cold and wet out) and i thought how good it was generally, went to shock rebould, they said for aoil change just let the gas out and remove the comp adjuster, pour old oil out and pour fresh oil in, then gas it up-WOW i thought ive been doing it wrong :confused:
So i read the full rebuild instructions-remove seal head and clip and remove shaft-then refit in reverse order and fill through the comp adjuster hole-no bleeding mentioned??????
any other manuals read like this??? hope they dont do it that way at the factory
Posted by: georgieboy---------------------
it is here the same outside, rainy.
Today i reread all mine old dirt riders. Found some ISDE tips. Great for my next enduro.
And I cld not find my boge-sachs manual so i just uses yr rm manual oke?
I made a small error-they do say to bleed it-with the comp adjuster out-however i find a small reseviour is needed to stop it puking oil all over the shock.I wouldnt try to do it the way they say.
next crazy thing-N2 pressure they say 9.8 bar or 139.5 psi-where do they get these numbers?? whats wrong with 10bar or 145psi??? has someone tested it and found it better at 9.8 bar???
Marcus you already know those answers.
dean you are meant to come and play in the playground-not spoil my fun
Ok well just for the record Im letting some gas out right now . HA HA
Posted by: bclapham---------------------
Marcus: i do hope the weather picks up soon for you back home if you have too much spare time and starting to think too hard about this stuff.
Does everyone read the manual each night?
Posted by: steve125---------------------
Nope! only you sir analness of gunby-mon!
You dont take it to bed??? and read it over and over???? line by line?
