O Frame Inserts
Posted by: ktm033---------------------
I have to wear my glasses when I ride. This season I wore glasses under a pair of Oakley O Frame goggles. Frequently the lenses of my glasses fogged due to low air circulation. I like the goggles but would like to use prescription inserts. I have talked with local optometrists and nobody seems to have an insert available for the Oakleys. I have e mailed Oakley and have had no luck with a response. Does anyone know of a company that makes inserts for the Oakley O frames or for a comparable goggle?
Posted by: biglou---------------------
Have you called Oakley directly? I had some questions about some sunglasses I was looking at, needed recommendations between a couple models, and I called them direct, got the info I needed, and placed the order. They were very helpful. They have a contact number on their website.
Posted by: CRboy167---------------------
Look in the back of the mag's there are a couple companys that make prescription lens for most goggles. Good luck
