Originally posted by bclapham so how do they work with a showa twin chamber fork? The chamber is sealed and the volume displaced by the damper rod is controlled by the ICS spring- thus, i dont understand that oil level (outer chamber) on a showa fork has any effect on damping rates. |
Originally posted by Jeremy Wilkey Good question and well your the inspiration to finally put this one to the key pad.. So here goes.. Heres one for DRN as well as your reading... So what else should this tell you? Don't buy anything with a check valve.. It will give the same bottoming effect, but you're not going to get the same plushness factor as the tanks will equalize more quickly and if your in big bumps, or you carry your wheel in the air too long your going to have issues.. It amazes me how designs can be so much more than they where intended for by chance alone.. BR, Jer |
Originally posted by Jeremy Wilkey Bruce, Wether open or closed cartridge how do you invison the air spring having anything to do with damping rates? BR, Jer |
Originally posted by bedell99 If I'm right the check valve's purpose in the too-tech design is to allow the rebound to not be affected. I think that would work better than a none check valve design. Either way the carbon fiber look of the enzo's do look the best. Erik |
Originally posted by Jaybird IIf I am not mistaken, the most important factor is the flow control valve, and not the volume of the tanks themselves. I wondering, has Ross or any of the others, decided to make their own flow controls? Perhaps ones that have a click detent for a more precise setting? |
Originally posted by Jeremy Wilkey ...the tank determines the rise of the internal presure, which determines how quickly the tank backfills wich is a critcal variable..So presure and volume eqauations would matter very much in the proper sizing of such a system... |
Originally posted by Jeremy Wilkey So guys work on something better... Not cheaper..... BR, Jer |
