Originally Posted by biglou
but with the 400/426's, exhaust cam timing was retarded one tooth.
- The WR was advanced one tooth compared to the YZF which opened the exhaust valve about 23 crank degrees sooner than on the YZF. They did this to improve blowdown with the restrictive stock exhaust system that came on the US WRs. Uncorking the exhaust negates any need for the silly WR cam timing, so anyone that changes the exhaust should change the cam timing to YZF spec as well. Same goes for the jetting to a large degree.
Originally Posted by SFO
I used to hate it when my Mom would spank me in public...
Originally Posted by Rich Rohrich
Lou knows I'm just tugging on the chain he left dangling.
Not positive about the 450cc models, but with the 400/426's, exhaust cam timing was retarded one tooth. Other than that, identical valvetrain. Hence the "YZ-Timed" WR's out there. There's plenty of WR's out there that have been YZ-timed, and are running the YZ seat and tank.
Originally Posted by Dewster
So you're saying that you would need to advance the timing mechanically by doing this and electronically by cutting the "gray wire"?
