Aluminum Polish
Posted by: 91KDX---------------------
Howdy,
I bought a pair of KX 250 forks from a Fellow DRNer and I stripped the ugly, chipped light blue paint off of the forks, and I am told that I should use some sort of Aluminum Polish on the outer tubes. I bought these forks for a KX front end mod to my KDX. I want to know what the aluminum polish is, where I can get it, how to put it on the forks, and what it does. Any info would be great.
Ben
Posted by: jaguar---------------------
what it is: an abrasive wet compound that you rub on with a cloth to scrub off any external corrosion so that a clean shiney surface is left.
you can buy it at KMart or WalMart.
Posted by: Jaybird---------------------
Mothers Aluminum Polish
I think it is more of an "etching" compound as opposed to abrasive.
Rub it on with a cloth and the surface will turn black-ish. Buff off the black with a clean cloth.
Posted by: wibby---------------------
Never Dull works pretty good too
Posted by: mdkuder---------------------
simichrome works great on finished surfaces!
http://www.newmantools.com/simi.htm
Thanks, I will check out Farm and Fleet to see what they have.
Ben
Posted by: Tony Williams---------------------
Airplanes use alot of this type of product. Try some of the outlets for airplane supplies.
aircraft spruce
Chief aircraft
etc
Posted by: m0rie---------------------
Another one that works pretty good if you can find it is Met-al Aluminum Polish. Seems to clean up the Aluminum fishing boat every year alright.
-Maurice
