Originally Posted by wannabe1
Hey all, first post here. I just bought a 93 KDX200.
The top-end has never been touched. There is some neglect and a little dry rot. The rubber boot between carb and cylinder will need replacing soon, is that a dealer part, or can it be found somewhere else?
I will order a Uni or Twin Air.
I haven't gotten the manual yet, so I will use the search and FAQ as much as possible, but may have to ask a few questions. Thanks.
fix the air boot and air filter first. Change the oil, use fresh gas and go easy on it for a while as the bottom end could have some sludge from old gas and oil, also may have a little rust. Change the oil when hot after each ride the first few times to hopfullly drain out said sludge, rust, and dead flys that may have found there way in there.
I would check the engine as soon as possible though.
