Originally Posted by Jeremy Wilkey
Shawn,
The reason its working over bumps is it not at a threshold of volume.. In other words its not doing much to anything... Take it off and you'll have more bottoming resistance than you do now.. Add more oil to increase the compression ratio to get working the way it should, and your bottoming will be better, only its going to suck in bumps.. Stick your one way valve closed, up your volume and you'll find it works much better.. I was working with my CRF this weekend and the Showas are more finicky than KYB's with subs but they are still a great mod.. I'm sorting out the short Enzo verse the long enzo.. For outdoor I like the big tank with real tight RSB for jumpy tracks the smaller tank works better.. BR, Jer |
