YZ400 & YZ250 Compatibility ?
Posted by: Zero---------------------
Anyone know if a front rotor off of a 03 YZ250 will fit on a 98 YZF400?
Posted by: biglou---------------------
I'm almost positive it will. The hubs were the same from 98-now to the best of my knowledge. The rotor might be a bit different, however. Full floater vs. not, for example. At the very least, the hole pattern will be the same. I just swapped my wheelset off the 01 426 onto my 04 450 and put the new rotors on the old wheelset. Also, White Bros. shows the same hub p/n for all the years mentioned above. Hope this helps. :thumb:
Posted by: whyzee---------------------
You'll need the 03 caliper. the newer rotor will bolt up to the hub, but the rotor diameter is larger.
Thanks guys!
Posted by: Matt90GT---------------------
FYI, the hubs up front changed in 02 to a wider unit.
Posted by: GBR39---------------------
Can anyone tell me what the cc displacement of a 250F is?
Posted by: kdxtodd---------------------
249cc
Thanks.
I was trying to figure out if I could ride in the 126cc to 200cc hare scramble C class but I guess I will have to ride the 201cc to 250 B Class. I didn't know if they would consider my 250F as a "125" or not.
