Compression Test
Posted by: kdxquebec---------------------
89 to 94 kdx200
I took 3 compression test last weekend on my 200 1989 with CLOSED throtlle. the engine was warm.
3 times i got 175 psi with 3-4 kicks.The manual says 119-185psi is the usable range with full open throttle.(i read after the test)
Would the bike will have higher results if i do the compression test with wot?
thank you
Yes.
Sucking air thru a closed slide is going to get you considerably less air than thru an open throat carburetor.
Which is why basic compression tests include a WOT.
