Front wheel offset?
Posted by: KAY DEE EXER---------------------
Upon re-installation of my forks and wheel, I have noticed that the front wheel is slightly off centre (closer to the caliper side fork leg) slightly. I havent measured it but as a guess its about 5mm closer to the caliper side. Its on a 98 200 so if someone could take a look at the gap on your bike to see if they are the same it would be greatly appreciated. Thanks all... :thumb:
Cmon please someone have a quick look for me. Im stuck and cant go any further till I rectify this. Thanks guys...
Posted by: wanaride---------------------
I just checked my front end ('03 200), and it looks as if the tire IS somewhat closer to the caliper side of the fork. It is really hard to tell though, maybe it is just the larger caliper vs smaller opposite-side hub diameter that is playing tricks with my eyes...
Would it be a PITA to give it a quick measure for me I will edit this post with my measurements. Thanks Wanaride !!! :thumb:
(EDIT) Ok well I dont really have anything to measure it with accurately but I can stick the end of a ruler in one side with a few MM gap. On the caliper side the ruler just fits in. If I had to guess I would say its a 4-5MM difference.
I bet others will chime in on this before I can take any measurements...I'm at work right now, but Lord willing, I'll take some measurements tonight and let you know what I come up with...
Your a champion as long as its not too much trouble. I have no problem waiting. Thanks again mate.
Posted by: mikdxer---------------------
Hello, I just measured mine and I have approximatley 1 5/8"
cleareance between the edge of the rim and the fork on either side, its right in the center. Hope this helps, its a 2002 kdx 200.
Mmmmmmmm I must have a problem somewhere.
Oh well off she comes again thanks mikdxer.
Posted by: johnkdx220---------------------
Kay Dee Exer,
This winter, I installed a KX front end on my 03' 220 and ended up with an off-set of approximatly 8mm. I stopped banging my head againt the brick wall because everything part did fit as intended and, most importantly, there doesn't seem to be a handling problem. Anyways, its still a mystery to me, but I've learned to live with it. The only remaining hypothesis: I did an "perfect off-set wheel truing!!!". (I used the KDX rim with KX hub and spokes).
This might not help you much except to say that you not alone...
Good Luck.
How's the odometer gear drive fit?
Posted by: Rhodester---------------------
Just eye balled mine. It looks so close to dead center it's hard to tell. I then dug out the tape measure and it may be a couple of mm closer to the disc side.
FWIW, I just checked mine ('03 200) and found that the front wheel appears to be approximately 3/16" (4.7mm) closer to the caliper side of the fork. The odometer cable fits into its housing with no problem...I had the front end apart last fall to grease the steering stem bearings so it is possible that I put it back together wrong, but it has not presented any (unusual) handling problems, so I figured it went back together right.
Any thoughts?
Thanks again wanaride Im guessing its right otherwise it would be hard to fit the rotor into the caliper when putting the wheel back on. I'll double check it now I have borrowed a set of calipers. I shall let you know what I find. :thumb:
Posted by: JasonWho---------------------
