Originally Posted by LoriKTM
He said learning trials techniques will help you in enduros-- but learning to ride enduros won't help you with trials.
) step that we had to go up. The problem was that you needed the correct technique to get up it otherwise major bruising. I got bruised a lot on this obstacle (4 crashes after 4 attempts) because if you didn't make it then the bike landed on top of you. The approach was also on an side camber, so you were a bit off balance on the approach. If the approach were flat it would have made the obstacle look less daunting, and it would have been easier starting the wheelie which was needed to be successful at the step. As it was I provided the usual entertainment and there were lots of smiles every time I had a go at this section
and it really hurt my confidence on the rest of the sections so overall I didn't do very well at the trial.
