Originally Posted by canyncarvr
I don't recall the plug on the RH side being so far recessed. Either that changed or I recall wrong. More likely the latter.
Good luck drilling it out. I didn't have any luck with that. As I mentioned drilling/tapping the hole and changing the attaching hardware to a bolt as opposed to the slip/joint fit of the guards worked fine. Maybe your bars are bent? Have you checked? I'm SURE they are. So..you need a new set!!! The aftermarket bars you get won't have this 'problem.' ![]() |
