KDX replacement headlight wiring
Posted by: Racer X---------------------
I just got a UFO KDX replacement light assembly, and the wiring is of course different from stock. I know that the red and yellow wires go to the headlight switch, and the other two wires go to the headlight. But this new headlight has 4 contacts. Two are for a little bulb and the other two are obviuosly for the bigger bulb. Any ideas on how I should wire it? Here are some pics. regular old 35w bulb, btw- so no new coil for me.
Contacts
Bulb
light
Posted by: Henk---------------------
Wire the big bulb as if it was the only one there. You can also take the switch off and plug the yellow and red wires directly into each other, This way the headlight is always on (and you don't have to buy another switch if it gets smashed).
Thanks, bro. That's what I'll do, since a new switch is $31, and mine IS smashed.
