Cracked kdx220 stock piston
Posted by: outrgus---------------------
Took my top end apart yesterday and found that my stock piston was cracked on the intake side I have less than 500 km on this new top end, so i would suggest to any one with any mods (pipe, reeds, etc) to be carefull. I know this has been posted before but i thought you could never have too many warnings. Just for your info i have used the stock piston before with the stock pipe and never had any problem until i upgraded my pipe and reeds. Glad i check my top end often, will have a wesico piston in it tommorow.
Posted by: trsrdr---------------------
I've been told by a reliable source that after the '97 model year bikes, it's good practice to replace the piston immediately due to piston failure.
Posted by: est142---------------------
definately. my 97 220 still has the original piston. there was a design change (for the worse apparently) for 98 and later kdx 220s. i would pull the piston in favor of a wiseco. i will probably do my own next winter.
