I BOUGHT A 84 RM125.IT WAS BOGGOING BAD SO THE DEALER SAID TO FITTLE WITH THE AIRSCREW..I CANT FIND IT.I HAVE A MAKINIE FLAT SIDE 34 MILL CARB..CAN YOU TELL ME WHERE THE AIR SCREW IS :moon: :moon:
It should be on the carb body, in between the airbox and the intake side of the slide, pointing outwards. If it's a fuel screw, it'll be between the cyl and the exhaust side of the slide. It also might be hiding under some gunk. Take a pressure washer to it with some Simple Green, and give it a good deusching...
