mopower440
- Jan 27, 2006
- 66
- 0
After 12 years of no bike, i decided i wanted another 2-stroke just to play in the field with, found a 1988 cr125, i bought it cheap enough. I pulled the carb and cleaned it and the jets out. Now, this is a flat slide carb, the only screw adjustment on the outside of the carb is a small flat blade screwdriver adjustment toward the rear of the carb really close to where the airbox mounts to the carb. now, what does this adjustment control and whats the baseline setting?
next, the needle adjustment on the slider is for WOT, correct?
thanks!
thanks!
