stripped right side down no teeth missing or worn put back together still slipping any ideasMicahdawg said:Common problem. Typical fix is to remove the kickstart ratcheting pawl and place more tension on the spring. It's pretty easy to figure out. You'll have to remove the right side case, then just a bolt or two will remove the whole ratchet pawl. Take the unit to your workbench, disassemble (there are like 6 pieces to the whole thing) and then upon reassembly you can place a washer or two in with the spring to make the spring tighter. Or you can just stretch the spring out. Either way, more spring tension takes care of the slipping problem. We did this fix on a 89 KX125 and took like 30 minutes.
