Hi there.
I need some help to correctly setup my pilot jet on my WR200.
I notice that when I turn in the idling screw, it goes in and makes the slide body pulls up leaving a gap in the carb body.
My current setting has a gap of about 3 mm.
I suspect something is quite wrong with my pilot jet size as my air screw is turned out 2 turns but with the slide body up with a 3mm gap(idling screw turned in almost all the way)....
Is the slide body supposed to be this high up or closed therefore blocking all air intake from the venturi and relying on the air screw and pilot jet????
:mad:
:mad:
