im guessing you mean in the gearbox? the gearbox and clutch share the same oil which is filled through the rubber bung on top of the clutch (side) cover.
an owners manual will tell you what sort of oil and how much, if you follow those directions you will never be wrong.
as for me i personally use automatic transmission fluid in my cr's gearbox as its cheap to buy and gives very good results. some other people use engine oil and some use specific 2stroke gearbox oils, its up to you. most 2 stroke gearbox's hold approx 700ml of oil as a guide (check manual first!).
i like to use a 2 stroke gearbox oil myself.. u have to be careful if u use a motor oil because alot of oils have additives in them which can make the wet clutch slip.
