I have a weird configuration on my '88 XR200R head. It had a non-stock decompression cam of some sort. I'm talking about the little shaft in the head with the lever welded on it that hooks to the cable that goes down to the kickstarter.
Anyway, I got a replacement lifter, and it is too far off the cam. It rotates 180 degrees before even coming in contact. I know I have it set up right.
What I would like is if someone has a lifter shaft (hopefully out of the bike), can they measure the shaft from the flat to the round of the shaft (i.e. the front to back of a capitol "D". My measurement is .160" or 4mm. You can pull the lifter shaft out by removing the 10 mm bolt on top. It slips in and out easy.
Thanks,
Toby
Thanks,
Toby
