HELP! Yamaha RT180 Ignition Coil 1997
Jittelkdx175
So, every website for the 97-98 RT180 shows the ignition coil as part #1 on the "Electrical 1" diagram. However in the parts list associated with it, Part #1 is the Regulator/Rectifier unit, which isn't even shown on this diagram. the 1990-96 model years all use the same ignition coil, but I want to double check before I order one.
I've already tried 2 different ebay coils with no luck and before I spend $90 on an OEM coil that I can't return after opening, I'd like to confirm the part will work. Anybody have a manual with resistance specs for a 90-96 model?
