Not to hi-jack but do you care to elbaorate about the carb shims?CR69r said:i'll trade you.
i've had both CR's. the only difference between the two in the motor department is the CDI boxes. i believe the cylinders are identical and the pipes might be slightly different - by only a hair. the 03 might have a bit more down low, but is still a turd in that department.
i've had mine ported, piped, Vforced, JD jetted, and race gased out, and it is still not as peppy as a stock 02 YZ250 i rode. if i'm at a track with jumps tight to the corners, i hate the thing. but for all other purposes i guess it works.
with suspension they updated some internals in the forks which serves as technical jargon and nothing you would notice on the track.
i'm looking for an 05YZ right now. but as one last resort i may try turining the carb into a 36mm with some kind of shims i heard about but can't find.
The inner chamber got bigger in the fork, but the only thing I find disapointing is the step back in the shock department. The high speed rebound on this shock is downright dangerous. With a shock revalve and a 22mm triple clamp, this bike rocks in the handling department.CR69r said:...with suspension they updated some internals in the forks which serves as technical jargon and nothing you would notice on the track...
Your probably thinking of the '04. It shaved a considerable amount of weight off the earlier CR's ( thanks to shared mods on the CRF's ).
oldfrt613 said:Actually, most of the weight savings I was referring to was in the smaller rear caliper/pad/reservoir ( I think the new rear brake sucks, especially from a durability standpoint ) and a reduction in hub weights, not the chassis. I believe most of those occured in '04. Most significant chassis change was in '05 with the front axel being pulled in 2mm on the fork leg, the '06 is unchanged from '05 - you are correct that the frames from '02-'06 are basically the same and the latest gen frame is only availible on the thumpers. I didn't really think all this info was necessary for this particular discussion.
My basic point was that in this particular case, since it was not for racing, that the '01 motor would be of more benefit than the subsequent chassis changes - just my opinion. The only year I haven't had any saddle time since '97 in is the '06.
