tightwoods
- Nov 23, 2000
- 87
- 0
The bike is a 2005 YZ250F with 62 hours on the engine. It backfires at low rpm and when downshifting. The cam chain was replaced and valves reshimmed at about 30 hours. Valves, springs, piston and rings are original. Valve clearances now are within range but on the loose side. I would have expected them to be tight. A leakdown test shows slight leakage down into the bottom end. There doesn't seem to be any leakage out of the intake or exhaust valves. How am I getting backfiring if the valves aren't tight? I would think that the valves and springs should be replaced anyway but what is causing the backfiring?
tightwoods
tightwoods
