mackmanj
7
I recently bought a 76 TS100 that is very good condition but is not running. I pulled the stator assembly and found that somebody had stuck a screwdriver in the coil that excites the ignition and cut some of the windings causing no spark at the plug. I repaired the windings,put the stator back on,and still have no spark. Does anyone know how to test the stator with an OHM meter. I was also wondering if the battery has to be charged to get spark or not. I used to work on small Honda 4 stroke cycles years ago,but this is my first Suzuki. Is there anything I need to know about how to time this engine or set the point gap setting? From reading other threads I think I understand how the oil injection system works and what type oil to use. I hope to get this bike running for me and my kids to ride on the weekends. Any help is greatly appreciated. Thanks, Jay
chillywilly
33
I might be wrong, but i do not think that there is any way to repair a stator at home. The wires could still be broke or the coating is damaged and leaking current. I think you will be looking at sending it out for rewinding or a replacement unit.As for testing it if you put the meter on the leads and check for continuity, not sure what #s you should see, but you should see something.As for your other requests, go get a service manual from somewhere or go to your public library and look there, ours has some great repair books on the shelf.
mackmanj
7
Turned out to be corrosion in the kill switch,corrosion in the key switch,and broken wire on the spark ignition coil. My repaired stator is working fine. I got lucky and found a wiring schematic on the internet. Thanks for your input ChillyWilly.
chillywilly
33
Good to hear that it's running, wow 3 strikes on the electrical system thats crazy.
