A couple of Jetting Questions
ryan
51
Well it is definately time to rejet my carb on my 01 CR 125 cause it is waaay too rich at least on bottom end. I was thinking of going down on the main one or two sizes, But I am really not sure which way to go on the pilot? Right now the jetting is stock 380 main, 45 pilot. Would really like some advise!! Thanks, Ryan:confused:
canvet
58
Hello Ryan;
The pilot jet and air screw control up to about 1/4 throttle. Leave the main jet alone if the bike is revving out clean. Leave the needle alone if there is no hesitation in mid-range. Lower numbered mainjets are leaner. Lower numbered pilots are leaner. Try dropping the pilot a size, if this helps but is still a bit rich, try another size smaller. Moving your air-screw out will also lean out the bottom. Good Luck.
Ricster
4
If you have questions on jetting and tuning a carb in general, Eric Gorr's link and web page have these in depth topic's. I am doing a lower end rebuild with the info off his pages.
_______________________________
Ricster
YZ 250
YZ 80
MXP1MP
1,845
What I ran in my '01 CR was this and it helped alot, #40 pilot with the 2071 (last 4 numbers most important) Needle in the 2nd clip position and left the main stock air screw at 1.5 turns out. this made a big improvement by changing the needle the bike needs it badly! I never got to test it out but I heard the #2171 needle is better than the #2071 needle. This will improve throttle responce once I put in that jetting specs the bike ran ALOT cleaner and bogged ALOT less on the bottom and overall.
ryan
51
Well I already ordered a #40 pilot and a 370 main, if this doesn't help enough I give the #2171 needle a try! Thanks.
Adrenaline
Mod Ban
Oct 26, 2001
245
I run a 50 pilot, 20-68 needle, 360 main and a/s at 1 1/4out. I have FMF fatty pipe and run 25 race gas and 75 pump. 32:1 motul 800 2T at sea level. Runs flawless.
ADR
Adrenaline
Mod Ban
Oct 26, 2001
245
one more thing
the 21-71 and the 21-70 needle are so alike. When I was going through what you are the 21-71 didn't do anything. If there is a 21-73+ needle go for it
