i have a 2005 yz250 F.. Everytime i adjust the chain i measure it all out so its perfect. when i put it all back together i torque the axle nut to the specs. But after the first ride it always changes. i do know why but is this normal. when i measure my adjustments on the swingarm i measure the adjuster nuts so they are exactly the same and it always comes out good but after the first ride, it pulls the chain side closer by about 1/2 to 1 mm more on the one side. so little there but when you spread that out and measur the diff from rim to swingarm its like 1/4 inch diff, does this matter? is it normal? as long as the chain and everythign spin freely is it ok to have the wheel not 100% perfectly aligned straight?
