mideastrider
827
Anyone every tried a Magnum Clutch Basket? I've used Hinson and Barnet baskets. None of them has a life span much different than a stock basket in my experience. I wish honda sold just a basket without gear probably would be half the cost. Was thinking of trying a Magum Clutch Basket but just wanted a little input from someone who has used one.
Matt90GT
1,517
I have used plenty of the PE/Magnum baskets and pressure plates. they wear way better than stock. I never have worn out an aftermarket basket to date, so I would be suspect of other components you have in your motor causing major wear.
mideastrider
827
"other components" Such as? I've went through baskets on ever bike my son as raced since he was on 85's. I will say the 85 and 250f not as bad as the 450. When I put the second basket in the 450 I also changed the hub and pressure plate (new oem). Never changed any thing else or had any problems with any other parts. And I always changed the fibers,metals and springs with new basket.
