Solid State
- Mar 9, 2001
- 493
- 0
Assume a brand new fully assembled KYB fork mounted on the triple clamps. No front wheel, no brake, nothing attached. If you grab the outer fork tube at its lowest point and then grab the inner tube at the bottom of the lug and then wiggle the lower tube front to back and side to side, should there be any movement/play? If so how much should the lug deviate in its movement? Wondering if it should be zero play (tight) like the wrist pin in a piston or tight like the non-vertical movement of the crank in its bearings.
When I perform this test, I get a couple milimeters side to side play measured at the bottom of the lug on the left tube and maybe one and a half on the right lug. The lugs are not loose on the inner tube, its the whole inner tune assembly has side to side play. The same play occurs if you compress the lower tubes an inch, they will still rock by the same amount.
The bike is a 2009 CRF450R and I just got the suspension back from being revalved. I did not do this test on the fork before I sent them out. The outer tubes were replaced with new coated tubes during the revalve.
I also noticed that the outer tube is not machined identical to the original 2009 CRF450R. The outer surface is completely smooth top to bottom where the original was only smooth at the clamp locations. Everywhere else the original outer tubes had raised machine/tooling marks. What do you suppose these tubes are off of? Never saw totally smooth outer tubes. They do not get re-machined smooth when being coated.
Thanks in advance.
Thanks in advance.
