Well, I just bought a V-Force reed block for my bike because I want as much
low end as I can get and from whet I've read, this was the way to go. So I
open the box and on a slip of paper it says to leave the reed tension in
the "high" setting or the reed life will be dramatically cut short. Hmmm. I
wanted the low tension setting to maximize the low end power. So
like any good DRNer I did a search on the subject and found lots of
questions on the same thing. Those that did go to the low tension setting
did not feel that the reeds failed prematurely but some found that they had
to go much leaner on the pilot jet. I also saw one comment that the reeds
fluttered when at the low tension setting.
That still didn't answer my question so I gave Moto Tassinari a call and
talked to one of their techs. He explained that the reeds that they use are
thin and are not as strong as some of the thicker reeds that they use for
other applications. The read block is common to several other applications (snowmobiles)
that use thicker reeds so the high and low tension adjustment is
appropriate.
The low tension setting with the thinner reeds can also fluttering, as
someone had already noticed, which can also cause problem. I asked about
possible jetting changes and he said that I might have to increase
the size of the pilot. I know some of you decreased the pilot size
but you may have thought you should because of the fluttering of the
thinner reeds. The tech said that in the high tension setting I should have
plenty of power on the low end as well the top. I plan on just leaving it at the low tension setting.
I can't wait for the weather to break so I can try it out :)
appropriate.
