- Feb 9, 2000
- 2,450
- 2
Mountain Bike Gas Electric Hybrid
OK, this may appeal to all the crazy tinkerers out there. I am thinking of building a gasoline electric hybrid powered bicycle for my kid. The idea started out with me wanting to get him a battery powered electric motor for his bicycle, the ZAP ZETA III which is an all in one unit sells for around $200. Then I got to thinking about using a weedeater engine which would run on gas. http://www.smallenginewarehouse.com/ I can find small gasoline engines selling for between $150 and $200.(I can get a new weedeater engine starting at $69) My only concern with using the weedeater engine, is that I could run into problems with the law if the system was direct drive (we might be OK here in TX!) - So, my next thought was on combining the two technologies, have a small weadeater engine drive a DC generator, which in turn drives a DC motor. I can get a small gas engine which weighs about 8 pounds (4 stroke weighs about 13). This will in effect give me a small generator, which if designed correctly, could be put to use in other applications. On the bicycle itself I could fit the electric motor, have it run on the rear tire. I would then have the option of either running the bike off a gel type battery, or directly from the weedeater engine.
Now, I am not an auto electrician by any means, so I will need to get my head around using an AC or DC generator, and an AC or DC motor. Obviously what I am looking for is something which is lightweight, efficient, and relatively cheap to put together.
I don't know if this is an exercise in futility, so for now I am going to do some more research and digging on the subject. Any input will be greatly appreciated.
