Im sure there is something Im missing but Ill ask a silly question anyway,--what keeps the oil in twin chamber forks from migrating out of the holes located at the top of the inner chamber? I.E laying the bike over etc?
Does the oil somehow circulate in these forks, the first set I built up I used a yellow oil in the inner chamber and green in the outer, next time I stripped them both chambers had green oil.
The inner chamber should be sealed from the other. Sounds like you have a bad seal somewhere. There are 3 places, the bottom seal where the shaft enters the cartridge, O-rings on the outer side of the base assembly and the inner seal where the floating piston rides on the base assembly. The last is the hardest to replace I've heard. Never done one.
