I had read that is normal to take the top end apart every so often to examine, and check things to make sure they are all since withing tolerances. If the ring end gap is still good, and the piston is still in spec, rod bearing ok, things like that, can I just get new gaskets and put it back together? I had heard that a look-see is good practice. Is this true? Can I reuse the rings if they are still within spec? Things like that...
Bleeds
Bleeds
