Well, I just picked up this bike and at the time, all it needed was a new ring (piston). Replaced it...
Well, I get about a tanks use out the bike and all of a sudden, the motor slowly (within seconds) dies out.
I take the motor apart, AGAIN, and find the new wiseco piston is all pitted on the top with scorn sides, and the ring is stuck in the piston.
My concluded that a piece of the old ring was still in the crankcase and finally got sucked up into the chamber. But, it does confuse me a bit. there was what looked like brass/copper shavings in the motor. What could this have been?
Now, with my Question....
I noticed the rod moves back and forth on the crank. Is this normal?
Also, I Does anyone have a good detailed picture on the motor/trans. I'm not sure if I put the trans gears in the right order and I would like to see a picture to make sure.
Thanks guys.
Thanks guys.
