If the rod slides left and right but not up and down is it ok or should it be replace? Also how much play is allowed for the piston on a dirt bike. Im not sure if its ok to still run my bike because the piston move alittle? When putting the jug back on is it ok to put oil on the piston and on the crank shaft, or is it a bad idea? I've heard both ways so i need a third opinion. Thanks
