You didn't install it correctly. Check to make sure the end of the bars is not rubbing on the inside of the tube. Check to see if the grip is rubbing on the throttle housing. Make sure there is slight play in the throttle cable. Make sure that the new throttle tube matches the old one. Good luck, YZ165
