brutepower2006
- Mar 12, 2006
- 7
- 0
ok the bike ran perfect for awhile then one day i ran it extremely lean and cracked the piston. only thing i can come up with is sand clogged the jet (sand settled on the bottom of the carb bowl). I tore it down (split the case due to i noticed a broken friction plate so i made sure there were no piece in the tranny) and put a wiseco pro-lite piston in it and put it back together (cleaned carb of coarse) cranked it up today 15:1 fuel/oil mix. castor 927. It pours out white smoke it used to be blue what causes that? thanks in advance
