dafuzz89
I recently was thumbing thru a 04 issue of dirt bike magazine and they had set ups for the 04 models. For the cr 250 they recommended a fmf pipe, 5mm spacer, v force reeds, 400 main jet, 37.5 pilot jet nad set the main needle in the second slot. My question is; does anybody have the same info for a 2002 cr250 that rides in Michigan?
bedell99
788
I have a 02cr250. If you are looking for a bolt on item to put on your bike, I had some good luck with a Vforce 3 reed valve. Next I would recomend sending you jug to Eric Gorr. For jetting thats a tough one and I have noticed it changes by alot on how you twist the throttle. but a quick recommendation is go leaner on the pilot and richer on the main.
Erik
