KDX1
Mod Ban
Jun 5, 2001
228
I am buying a 1967 Pontiac Firebird and went to look underneath up under the rear of the vehicle and noticed that there were no shock absorbers, just the leaf springs. Aren't there supposed to be shocks on the rear, or did Pontiac not use shocks on the rear of these first generation "birds"? Any insight on this would be greatly appreciated. :think:
smb_racing
Master of None
2,085
I would think it'd have shocks, are there shock mounts?
WoodsRider
2,812
Originally posted by XRpredator
Should have shocks, but only one traction bar.
Just like any good roach mobile or exhaust leak special! ;)
Offroadr
Ready to bang some trees!
Jan 4, 2000
5,227
25
I be that baby bounces like a pogo stick!!! :scream:
XRpredator
AssClown SuperPowers
13,510
Seriously, in '67 the Camaro and Firebird only had one traction bar to counteract wheelhop.
Can't be having wheelhop, it shakes up the beer that you have resting in your crotch! ;)
Rooster
Today's Tom Sawyer
3,300
Hey Pred! What's up with the Meatloaf lyrics?!! :)
KDX1
Mod Ban
Jun 5, 2001
228
Thank you everyone for the replies. I didn't get close enough to see if there were any shock mounts, but after talking with a co-worker, he said that it should have shocks too. It might be that the mounts were rusted off, and the previous owner just took the shocks off all together. I will inspect closer. I will be putting shocks on it, that is for sure. I have never driven a car without them, and I dont' want to either. :eek:
Jaybird
Apprentice Goon
6,452
Charlestown, IN
I used to race a '67 GM frame. They have shocks.
Tieing the frame together and adding ladder bars works wonders for wheel-hop on that particular model. Weight jacks also help them hook up mucho well on the dirt too! :)
( I won't mention welding up the spider gears. :eek: )
WoodsRider
2,812
Sure makes a lovely sound when going around a corner! ;)
KDX1
Mod Ban
Jun 5, 2001
228
Speaking of welding the spider gears, I plan to put a "locker" in the rear end. What is the best make to use and also, would this be a hard job to do my self. Are there any special tools that would be required to do this job? This car will be driven on the street and taken to the "strip" ever once in a while. :aj:
MikeT
4,112
11
Push the bak of the car down hard. If it bounces and doesn't stop, the shocks are missing. If it stops and doesn't bounce, then you just missed where the shocks were mounted.
Smitty
Alowishus Devadander
Nov 10, 1999
707
I doubt you can install your own locker, due to setting the lash which requires some special tools and knowledge. As far as brand, I have a Detroit in my car and have no problems. However, some of the newer style lockers may be a little smoother. Air lockers?
WoodsRider
2,812
IMO the two best "posi" rear ends came as a third member in a Mopar 8-3/4" or Ford 9" rear ends. I never liked GM's "C" clip arrangement.
splatt
Resident mental case
908
14
The rear shocks on GM F-bodies(Camaro,Firebird)are on the outside of the frame between the tires and the leaf springs. Take the tires off and they should be right there.
Steve
Jaybird
Apprentice Goon
6,452
Charlestown, IN
Yup! The sound of dirt roosting! :D
(not sure what right turns sound like)
