bonzo
56
While greasing the rear lincs and swingarm pivot I removed the spring
loaded chain tensioner. I was wondering if anyone new of an easy
method to remount tensioner? I think it would be very easy toaccidently
cross thread mounting bolt. Sure could use help. Is this a case of maybe
laying the bike on its side and whith two people just restling it on?
wayneg
544
If you contact Gas Gas USA they will have a cunning plan on how to reinstall your chain tensioner. There is a technical help board which also may have some tips on it. Good Luck!!
MCMAN56
84
I had the same problem. If I remember correctly, I removed the block that the chain travels through. Then I bolted the spring with arm to the swing arm. It was pretty easy to pull the arm down and reinstall the block.
