Did someone in SoCal wrecking Crew just get their motor back from Eric Gorr?
If so, how was it and did you get an over bore?
I trashed my bottom-end and the top-end will need to be replaced too. I was going to do the top, but that was before I knew the crank/rod was trashed. I've now set my sights on getting a larger displacement and a full tungsten disulfide rebuild to get a motor that will work for my weight, size and ride needs.
Just wondering what others have done. Looks like I'll be spending close to 1K for everything and all mods. It would have been cheaper to find the 300, but I'm in this hole now and I've got to climb out. Unless there's someone out there that is in need of a yz250, less a motor.
Thanks for any feedback.
