I finally decided to do it myself for the first time... I followd all the directions and everything... I practiced a couple times getting the cylinder over the old piston and old rings... then I installed the new piston and rings and put it back together... I go to torch the bolts down and one of the studs just came out... I thought it was over for sure... I pull the cylalndar back off and I realise that the stud's threads are completely gone! The shop I took it too looks like they just loaded it up with lock tight holding onto like two threads that were left...
So I went to the auto parts store bought the next size larger stud, and tap and taped that thing the next size larger... I was scared it wouldn't work, but I taped the new threrads clean and put the stud in...
That's when the fun really began... The mounting hole on the cylinder: too small... So I had to drill it out... I was afraid Id ruin it, but I did it anyway... Finally got the top end on, torched it down... If fired up right away... I drove it around for 30 minutes let it cool down...
Finally I load up the bike, to go ride at Johnson Valley nice and early get it broken it the rest of the way... I get out there and the I start the bike let it warm up then I go about 1/4 mile... bike dies, won't run for nothing... can't push it in the sand to push start it, I'm thinking of all the things that could have gone wrong... I bring it home, tear the carb apart, clean everything, I'm thinking maybe I should insect the kips and clean all that out? I mess with he mixture screw... I try and think of everything... should I tear it all back down? Finally after about half the day goes by I decide to go out and buy a new spark plug... wouldn't ya know, it fires right up after that and runs so much friggin better than I even remember it running... it's like a new bike now!!!
