smooth sail
- Dec 10, 2001
- 42
- 0
I have purchased and installed the EBC oversize rotor (280mm). Man what a monster that thing is compared to stock! Here is the question/problem. With the KX routing the brake line under the fork, the stock brake line is rather tight- too tight for my taste, and I feel that it could become a safety issue. The caliper is moved much further away from the stock position, and because of it location, it has taken nearly all the slack out of the line. A Fastline braided line for the 97-2000 KX's looks long enough,(approx 20mm more) and still routes the factory way, however the stock line clamp on the KX has a step in it that captures the stock line and holds it firm, the Fastline is a single diameter at the bottom. When tightened, I think it will crush the Fastline hose. Routing CR style is not an option for me. This bike already has an affection for fork guards, cracking the mounting holes regularly. I can only imagine what will happen when the top guide is removed, and a brake line is flexing the top. Any suggestions or comments? Yamaha and Suzy riders- are the brake hose clamps at the bottom of the forks stepped or one diameter? Thanks!
Smooth
Smooth
