joereitman
- Jul 2, 2003
- 540
- 0
I run my levers way in and want a perch that works better than stocker at keeping lever in on short bars. All I have found is this- anything similar y'all aware of?
Quote:
Our solution is to maintain the lever length and therefore the easier pull characteristic, but to allow the inset positioning by creating an angle in the perch. The limiting factor on perch placement is the bend in the handlebar and clearance in the back of the lever for the grip ring. With the "angled" perch and extended grip clearance of the Forever Lever you can inset the mounting position for the most protection available.
http://www.dirtbikestore.com/acatalog/TEC_Inc_Unbreakable_Levers.html
Also looking at Moose :
Quote:
Two cable locating positions (shown on bottom of lever) allow for adjustable leverage and an easy pull
Needle bearings provide a smooth, consistent feel
Removable rubber guard keeps mechanisms clean and operational
Nylon insert allows perch to rotate during impact
Pivoting cable adjuster makes cable tension adjustments easy
Adjustable reach for personalized lever angle
Constructed of polished cast aluminum alloy
$49.95-$59.95
http://www.mooseracing.com/catalog....level3=1178&level4=1180&product_group_id=5355
$49.95-$59.95
