I thought that I had a loose steering head, and needed to service the bearings anyway, so I just finished doing the job. Discovered something interesting, though: my steering head wasn't loose, but there's play in both of my forks between the lower and upper. If I grab the lower in one hand (fork extended) then grab the upper in the other I can rock the bottom of the lower (where the axle goes through) pretty much in any direction just a little bit. Feels just like a loose head, except the play's between the sliders.
I also disassembled my fork while doing the head (second time) and everything looked good, although I didn't pull the main seals or separate the inners from the outers, so I didn't get a look at those bushings (I assume theres a bushing at the top of the lower and the bottom of the upper.
Is this slight play normal?
Thanks,
Brian
Thanks,
Brian
