mike-evans
142
havnt rode my bike for about 3 weeks, so went to change the tranny oil, and before i did, with the bike in neutral i pushed the kickstart down and the rear wheel turns, why? Is there anything to worry about? If i hold the wheel it wil stop, but a little resistance there...it has new clutch plates and basket, its a 01 yz 250 2t....
Matt90GT
1,517
because the plates are dry and or sticking. Pull the clutch in, put it in gear with the front brake on and it will loosen up once it gets oil on it - since you say it is new.
mike-evans
142
ok when i say new, its about 3 months old and about 5 rides on it, it hasnt done it before, i think it might just need to be run and then loosen up prehaps? If not, what could it be, why would it drag and spin the rear wheel?
jumpingjoe628
176
All of my bikes have done this. It's just drag from the transmission. If you start the bike even if it's in neutral, the rear wheel might rotate a little. Perfectly normal.
