somple Q 02-01 CR250 rear spokes, the same?
ZOMBIE666
324
simple Q 02-01 CR250 rear spokes, the same?
like the title said, are 01 and 02 cr250 rear spokes the same?
i ask because i just got in my new rear spokes for my 02 and on the bag it says 89-01 cr125-500
84cr125flyer
49
When you lace your wheel, the inner spokes are 3mm longer than the outside ones. What I mean by this is as the spokes cross next to each other at the hub not near the rim, there is an outside and an inside, this is where you put the long on the inside and short on the outside. In your kit there should be an A (107mm) and B (110mm). I know it doesn't make sense but a friend of mine and I laced two different wheels thinking the A was on one side and the B was on another and still did not get the correct results (three times each). Finally a call to Excel got us on the right track and both wheels laced up perfect. Hope this helps.
